Crash in 7.1 with Shift-drag of icon
The following steps cause a crash every time on my WinXP box:
1) Create a new, blank VI.
2) Drag any non-Express subVI (e.g., Trim Whitespace from the Additional String Functions palette) onto your block diagram.
3) Double-click on the subVI and change some of the values on its front panel (e.g., choose a different Location option on the Trim Whitespace panel).
4) Shift-drag the icon from the subVI's front panel to the subVI's icon on your block diagram. This is supposed to cause LabVIEW to drop constants onto your VI's diagram.
5) LabVIEW crashes with an access violation at address 0xC0000005.
This fails with every VI I have tried, including both NI's and my own. I have never seen Shift-drag succeed in 7.1, and
I have never seen it fail in any older version.
(2,614 Views)
Thanks for notifying us this problem. I have reported it to the Engineers. Sorry for the inconvenience.
At the mean time, I found that for step 4 described above, if you do not drag the icon to the existing submenu icon, LV won't crash, and LV will create constant for you as well. Maybe this is a workaround for you.
Also, you can open a VI from the palette directly.
1. Pin the palette that has the VI you want.
2. Right click on the VI icon on the palette.
3. Select "Open VI". LV will open it for you without dropping it to the diagram of another VI.
Hope this helps.
(2,614 Views)
Thanks for the workaround. This appears to run fine on my PC.
By the way, I made a mistake in my original post: I said, "Shift-drag" instead of "Ctrl-Shift-drag."
Thanks again for your quick reply.
(2,614 Views)
