01-08-2007 07:04 AM
01-09-2007 03:55 AM - edited 01-09-2007 03:55 AM
Message Edited by Support on 01-09-2007 09:42 AM
01-09-2007 04:35 AM
01-09-2007
09:42 AM
- last edited on
05-29-2025
01:24 PM
by
Content Cleaner
Hello Bertrand,
I apologize that you are experiencing one of our known issues. I’m not too sure where Pierre got the information that “[t]his bug is corrected in LabVIEW 8.2.1 patch which we will release soon”. We haven’t released any information on whether we will release anything for LabVIEW 8.2, and we certainly haven’t given any sort of time-line for that. If you are interested in learning about our software updates, be sure to visit our drivers and updates page.
With regards to the issue you are experiencing, I am interested in finding a workaround for you to use so that you do not experience this crash. Pierre, please provide the CAR number you are referring to so that others tracking this issue can more easily research the issue. Are you referring to CAR 42J25NQK? One customer that experienced this crash was able to resolve the error by placing more controls/indicators on the front panel, and then manipulating the properties through the dialog box. Another customer reports that programmatically writing the properties through property nodes seems to work just fine. Do either of these potential workaround resolve your crash?
Thanks for posting your question to the NI discussion forums. Have a great evening-
01-11-2007 03:29 AM
Hello Travis,
I succeeded in finding a workaround thanks your advice. In fact instead of opening the property window directly, I use the other contextual menus ( right-click on the command) proposed above the property menu. All properties are not directly available, but in my case it is sufficient.
Bertrand
01-11-2007 04:18 AM
01-16-2007 01:43 AM - edited 01-16-2007 01:43 AM
Message Edité par pierreR le 01-16-2007 01:45 AM
01-16-2007 01:54 AM
Hello Pierre,
Yes, I tried on two different computers, and I have exactly the same problems.
I will call the NI office.
bertrand
01-19-2007 10:28 AM
