Crash when passing a pointer of an initialized U8 array to my dll file.
I need to pass the pointer of an initialized 1D array of U8 type to my Dll file. At first, I set the length of the 1D array and initialized it. Then I configured the Call Lib Node and made the input parameter as 1D Array Pointer of U8 type. The prototype of the called function in my Dll file is:
EXPORT void Grab(unsigned char *LVPict)
Also, I had a goble pointer of 1D buffer in my Dll file, defined as LPBYTE pImage, and I wrote the data in the goble buffer to the 1D array, using
for (DWORD i=0; i
But after I run the VI, LabView crashed down every time until I reduced dwSize, the legth of buffer, to 1. That means, I can not write anything from the buffer
to the array.
I'm very very sure the array initialized in LabView is far far huge than the goble buffer.
(2,599 Views)
It's because the array is not set up like the standard C array. Read "Using External Code in LabVIEW" in LabVIEW's help. Also, if you right-click on the Call Library Node and select the option to create a header file, the header file will show the data structure more clearly.
(2,599 Views)
