Crash when selecting "Create Variables"
If I start with a completely blank project, create a Library, then right-click on the library and select "Create Variables...", LabVIEW crashes to desktop. It also does this with "Create Bound Variables...". It does not crash if I use right-click -> New -> Variable. Any idea what might be causing this?
I'm on LabVIEW 21.0.1f2 (64-bit) on Windows 10 Pro (10.0.19042)
(2,449 Views)
Hi  LambdaKnight,
Can you attach some screenshots of crashed window for a clearer understanding?
(2,401 Views)
Sure. Not sure how much help it'll be. Click on the highlighted option and the entire application crashes. Nothing else except for the Windows crash dialog. The Event Viewer has this:
Log Name:      Application
Source:        Application Error
Date:          9/15/2022 7:37:33 AM
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      lap2
Description:
Faulting application name: LabVIEW.exe, version: 21.0.1.4002, time stamp: 0x62a97821
Faulting module name: MVEProvider.mxx, version: 21.0.1.49152, time stamp: 0x61dd703b
Exception code: 0x80000003
Fault offset: 0x00000000000291e7
Faulting process id: 0x17c4
Faulting application start time: 0x01d8c85569f456e0
Faulting application path: C:\Program Files\National Instruments\LabVIEW 2021\LabVIEW.exe
Faulting module path: C:\Program Files\National Instruments\LabVIEW 2021\resource\Framework\Providers\MVEProvider.mxx
Report Id: 6e23003f-84a7-4a8f-9d88-4209e8864998
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>100</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2022-09-15T13:37:33.9903328Z" />
    <EventRecordID>183794</EventRecordID>
    <Correlation />
    <Execution ProcessID="0" ThreadID="0" />
    <Channel>Application</Channel>
    <Computer>lap2</Computer>
    <Security />
  </System>
  <EventData>
    <Data>LabVIEW.exe</Data>
    <Data>21.0.1.4002</Data>
    <Data>62a97821</Data>
    <Data>MVEProvider.mxx</Data>
    <Data>21.0.1.49152</Data>
    <Data>61dd703b</Data>
    <Data>80000003</Data>
    <Data>00000000000291e7</Data>
    <Data>17c4</Data>
    <Data>01d8c85569f456e0</Data>
    <Data>C:\Program Files\National Instruments\LabVIEW 2021\LabVIEW.exe</Data>
    <Data>C:\Program Files\National Instruments\LabVIEW 2021\resource\Framework\Providers\MVEProvider.mxx</Data>
    <Data>6e23003f-84a7-4a8f-9d88-4209e8864998</Data>
    <Data>
    </Data>
    <Data>
    </Data>
  </EventData>
</Event>
(2,385 Views)
Because you "hid your code" (you didn't attach the Project, so we can't open the Project file to see what you covered up with the Dropdown), I'm not certain I reproduced what you tried to do.  I created a blank Project, dropped a blank Library, right-clicked and said "Create Variables", and got a Batch Variable Creation screen.  No crash.
I was running LabVIEW 2021 SP1 (32-bit), not (64-bit).
Is this a recent installation of LabVIEW 2021?  Is there a possibility of a mis-install?
Bob Schor
(2,372 Views)
Nothing was covered up by the drop-down. You did exactly what I did. That you're not getting a crash does seem to indicate it is something wrong with my environment. I shall look in to it more.
(2,344 Views)
I removed MVEProvider.mxx from the installation and then ran a repair on LabVIEW to see if maybe that would fix it. It did not. Still crashes. LabVIEW 2022 Q3 doesn't crash when I do the same thing.
(2,339 Views)
Then I think either you should use LabVIEW 2022 Q3 for avoiding any crashes, or uninstall and reinstall your drivers if you want to stay in 2021 version.
Regards)
(2,269 Views)
