Crear un menu personalizado
Buenos dias,
Estoy actualizando una aplicación realizada en labview 5.0  a 8.2 y esta tiene un menu.rtm, tiene diferentes acciones y me gustaria saber ¿ como funciona esto? Si hace una llamada algun VI porque no veo que no haya nada asociado.
Un saludo y gracias.
(4,427 Views)
Hola,
I dind't understand exaclty what is the problem, but maybe the following can help a bit:
Creating Custom Run-Time Menus in LabVIEW
Saludos,
Christian
(4,425 Views)
I'll try to explain in English, I have a file that menú.rtm but not VI executes files or how.
The link you give me I have seen but not taken me out of my doubts.
(4,420 Views)
Hi Noelia,
that menu.rtm has to be linked with the VI in question. You are asked "Replace by custom menu" when closing the RTM editor...
When the vi is in running mode you will see your user-defined menu and are able/have to check user actions (best bet is the event structure...).
Message Edited by GerdW on 12-10-2009 10:01 AM
(4,415 Views)
have not explained properly. The menu has 3 options: - Load - Save - Out These 3 options do you have to have a VI mandatory?
(4,403 Views)
Since your VIs where made with LV 5.0 the rtm menu could only be handled with the Menu VIs, e.g. "Get Menu Item Info".
You will have to search where these VIs are used in your code and then add the custom rtm to the the respectiv VI.
Christian
Message Edited by Christian_M on 12-10-2009 03:13 AM
(4,402 Views)
