Creat Array from real time elements
I need to creat an array from elements (point by point). Each element should insert into array after processing in while loop.
Then I need to plot array.
(3,566 Views)
Check the examples that ship with LV. There are many that show how to do some variation of what you are asking for.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,559 Views)
Dear mikeporter
In the attached figure you can see the problem with creating array from elements
(3,548 Views)
Try moving the Gain graph outside the loop and delete the array builder. Now wire from the result of your calculation to the graph. Right click on the tunnel where the wire goes through the wall of the loop and select Auto-Index.
Mike...
LabVIEW Champion
(3,543 Views)
Dear mikeporter
First, thanks for fast reply. Second, thanks for solving my problem.
regards
Eng A Wahpy
(3,529 Views)
