Create A/O reading from excel spreadsheet
There are also numerous examples on this site.
Message 11 of 13
(598 Views)
The USB-6229 has four analog outputs and would meet your requirement of outputting four waveforms.  As mentioned in previous posts, without more information about the timing requirements it is difficult to say if the USB-6229 will meet your needs.  Take a look at the examples that have been referenced in previous posts.
If you open LabVIEW and go to Help >> Find Examples you can access the Example Finder.  In the lower left corner you can select a hardware device like the USB-6229 (in drop down menu select Add Device) and find only examples that will work with that device by selecting “Limit results to hardware.”  This will show you many of the hardware examples that will work with that device.  Many of the examples mentioned in previous posts will also work.  Most likely you can piece together your custom program by looking at several different kind of examples.
Jared T.
Message 12 of 13
(573 Views)
I'm going to check a couple examples and see what I come up with. Thanks for the help and suggestions.
Message 13 of 13
(565 Views)
