Create CIN with visual studio 2010
I try to create a CIN with Visual studio 2010. For that I follow step by step the 2 links below :
http://zone.ni.com/reference/en-XX/help/371361G-01/lvhowto/creating_cin_mult_two_num/
http://zone.ni.com/reference/en-XX/help/371361G-01/lvhowto/compiling_cin_source/
I've got an error when compiling :
NMAKE : fatal error U1073: incapable d'obtenir 'mult.obj'
stop
I initiate the C code of the CIN with with LabVIEW 2010 (see below)
Someone could help me
JP
(3,459 Views)
Why are you trying to do this? A CIN is obsolete and no longer supported.
(3,456 Views)
thank you for your answer.
I want to do that because I juste want to modify an existing Lv api based on CIN.
you said that CIN is no more supported is it official ?
if it is the case why could I find help on CIN in LV 2010 help and LV 2011 help?
JP
(3,436 Views)
Indeed the CIN is no more supported under new versions of LabVIEW (it is explain in the help of the CIN node in the function palette.
In fact, I think you can use old version of CIN development, but you can't create new development on this technic : this article (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LubSAE&l=en-US §2) explain that.
So you should use the call Dll node instead of the CIN node (mainly to call a function like a Ic_InitFlowControl())
Smiley Wink
(3,425 Views)
