Create DLL from VI and call in TestStand
i´m using LabView 8.21 and Teststand 3.5. Currentlly i´m playing with the project-Explorer where i´m creating DLLs.
The first and easiest step was to create a new VI with string-in and strig-out.
Then i added this vi to my project and created a DLL from it.
This DLL is called in TestStand where the parameters are automatically detected.
But when i add an boolean-input and boolean-output und do exactly the same then Teststand says:
 "This function either does not have parameter-information in the DLL or uses types not recognised by teststand."
The type of the boolean is "LVBOOLEAN" in the created header-file.
What am i doing wrong? Why is this simple bool-value not working? I bool works not then i can never use the Labview-error-out-cluster inside a DLL?
Or is there an easy trick to solve this?
Thanks for your help
Message 1 of 1
(2,391 Views)
