Create Express VI with varying numbers and types of terminals
Hi, I'm trying to create an express vi that has different numbers and types of output terminals depending on what a user selects. Can anyone point me in the right direction? Does anyone know where I can find examples or tutorials?
(3,023 Views)
Accepted by topic author sunnysideup
Assuming that you *really* want to do this, you can purchase a toolkit from NI to create Express VIs.  I personally use Express VIs about as often as I use local variables (ie. not if I can help it).  I would recommend that you consider polymorphic VIs instead (search Help for polymorphic).  If you really want to go the Express route, you'd better hurry, the toolkit is only being sold for another week.
(3,009 Views)
Express VIs are just flimflams glued into Labview with cheap glue. Invest your time and money in something better
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,005 Views)
