Create FPGA project without NI board
Is it possible to create an FPGA project without having R series board connected?
Can this project be run in emulation mode?
I followind the NI knwoledge base here: http://digital.ni.com/public.nsf/allkb/F466AD83D24F041D8625714900709583
But it doesn't work:
Thank you,
(3,008 Views)
Do you have the LabVIEW FPGA toolkit and NI-RIO drivers installed? It looks like you don't have the support for RIO/FPGA devices installed.
I have a lot more items listed under Add Targets and Devices.
Have a look in MAX and see if you have NI-RIO, NI R Series Multifunction RIO and FPGA (under your LabVIEW version) listed.
(blog)
(2,998 Views)
here what I have in MAX:
What next?
(2,988 Views)
The version of RIO you have installed is very old so probably isn't compatible with LabVIEW 2013 - it was released in 2009. I suggest updating to the latest version for LabVIEW 2013 - I think it is RIO 13.
This should be the link to download: http://www.ni.com/download/ni-rio-13.1/4572/en/
If you expand the LabVIEW 2013 f1 item - does it show FPGA?
(blog)
(2,974 Views)
