Create Labview interface for arduino to send data through LoRa
I am sending and receiving data through LoRa technology, that I have stacked a LoRa shield on an Arduino UNO.
Recently, I am trying to create an interface with Labview, to enable me to control the Arduino with LabView.
The problem is that I do not know how can I create a Labview code to enable the Arduino-LoRa device to communicate through Labview interface.
I have added the Arduino code as if it might help to figure out what is happening.
  LoRa Simple Arduino Server :
  Support Devices:
  * LoRa Mini
  * LoRa Shield + Arduino;
  * LoRa GPS Shield + Arduino.
  Example sketch showing how to create a simple messageing server,
  with the RH_RF95 class. RH_RF95 class does not provide for addressing or
  reliability, so you should only use RH_RF95 if you do not need the higher
  level messaging abilities.
  It is designed to work with the other example LoRa Simple Client
  modified 16 11 2016
  by Edwin Chen <support@dragino.com>
  Dragino Technology Co., Limited
#include <SPI.h>
#include <RH_RF95.h>
# include <Wire.h>
#include <LiquidCrystal_I2C.h>
# include <LCD.h>
LiquidCrystal_I2C lcd (0x27,2,1,0,4,5,6,7,3,POSITIVE);
// Singleton instance of the radio driver
RH_RF95 rf95;
int led = 7;
int button=3;
int buttonstate=1;
float frequency = 930.0;
void setup()
  Serial.begin(9600);
  while (!Serial) ; // Wait for serial port to be available
  Serial.println("Start Sketch");
  if (!rf95.init())
    Serial.println("init failed");
  // Setup ISM frequency
  rf95.setFrequency(frequency);
  // Setup Power,dBm
  rf95.setTxPower(13);
  // Defaults BW Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  Serial.print("Listening on frequency: ");
  Serial.println(frequency);
   pinMode (button, INPUT_PULLUP);
    pinMode(led, OUTPUT);
lcd.begin (24,4);
      //                          LCD starting words
   lcd.setCursor (0,0);
lcd.print(" Hello ");
    lcd.setCursor (1,1);
     lcd.print("This is Server ");
delay (5000);
//                                Working Channel
lcd.clear ();
lcd.print(" Operating code ");
     lcd.print("channel: 2");
delay (5000);
  //                                            LCD setup             \\
lcd.clear ();
lcd.print(" Waiting for ");
lcd.setCursor (0,1);
lcd.print(" the client ");
//%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% Loop %%%%%%%%%%%%%%%%%%%%%%%%%%%%
void loop()
  int buttonstate=1;
  if (rf95.available())
    Serial.print("rf ");
    // Should be a message for us now
    uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    if (rf95.recv(buf, &len))
      RH_RF95::printBuffer("request: ", buf, len);
      Serial.print("got request: ");
      Serial.println((char*)buf);
      Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
       lcd.clear ();
     lcd.print ("Red LED is on");
       lcd.print ("Push the butoon");
       //while (digitalRead (button)==HIGH){
       // buttonstate=digitalRead (button);
      lcd.clear ();
      // Send a reply
      uint8_t data[] = "And hello back to you";
      rf95.send(data, sizeof(data));
      rf95.waitPacketSent();
      Serial.println("Sent a reply");
      digitalWrite(led, LOW);
      lcd.clear ();
     lcd.print ("Blue LED is on");
       lcd.print ("Reply is sent");
    }    else {
      Serial.println("recv failed");
(5,776 Views)
Hi Saeed1994,
I've seen LINX be used to communicate with Arduino. I would give that toolkit a try. Here is an article about controlling an Arduino from LabVIEW
David F.
Applications Engineering
www.ni.com/support
(5,731 Views)
Well I don't think there is any LINX vi's that directly control LoRa shields... But you can add a custom command to LINX
That being said, I think it would be easier to just write your Arduino Sketch in native Arduino code using the LoRa libraries that are available and also program the Arduino to respond to commands sent over the serial port to turn the LoRa on and off.
Using LabVIEW to control an Arduino like this is no different than controlling any other instrument on a serial port. In fact is is easier because since you are programming the Arduino you get to decide how the LoRa on/off command and Arduino response is formatted.
Forget about LabVIEW and get it working through the Arduino serial monitor first.
Then write a LabVIEW program that does what you were doing through the serial monitor by pressing a button or something instead of typing a command into the serial monitor
=== Engineer Ambiguously ===
(5,720 Views)
