Create Match Pattern in NI Vision Builder Interface
is it possible if I want to create a match pattern on interface instead of using the current one in configuration of NI Vision Builder? Because I need to keep on changing the pattern so I did not want to switch to configuration everytime I need to change the pattern.
(1,240 Views)
Please show us (with example data, please, and in executable form, meaning attach your VIs) what you are trying to do.
Bob Schor
(1,227 Views)
