Create Square Wave Signal (Clock Signal) Using USB 6343
Hello, I need to create a 1.4MHz square wave signal (it will be a clock input for a prototype circuit). I'm having a hard time creating this signal and making the output go from 0V to 5V. I found some example VI's which I'm trying to follow. One VI I found was a PWM Signal example, which I'm hoping I can use by setting the duty cycle to 0.5.
Attached is the VI I found. The problem is when I look at the output on a o-scope the peak voltage is only 0.5V, not the 5V I need. What could be causing this? Any help is created appreciated.
(3,449 Views)
Hi akhurash
There are examples in the NI Example finder in which you can search and base your code.
I have attached a snippet from the NI example finder of a continuous train pulse with a specific frequency
Regards
Esteban R.
(3,427 Views)
I know this thread is old but I wanted to mention that the reason I was getting the 0.5V output instead of 5V was because my ociliscope probe was set on 10X gain. I thought I would mention this if anyone else had a similar issue.
(3,321 Views)
