Create SubVI - Priority subroutine
Why is it not possible to create a SubVI from a code with a subroutine priority ? (with "Create SubVI")
(LabVIEW should just set the SubVI with the same subroutine priority)
Is this an expected behavior ? and, if so, why?
(3,621 Views)
Accepted by topic author ouadji
It looks like this behavior already has a CAR associated with it. The CAR number is 383301.
I'm sure you have done this already, but the workaround is just to create the subVI manually or to lower the priority and create the subVI (making sure to put both VI's priority back to subroutine).
(3,589 Views)
" CAR number is 383301 " ... ok, thank you Jacobson.
"I'm sure you have done this already, ... "  yes, indeed, I already use this workaround.
Thank you for this quick reply.
(3,584 Views)
