Create TDMS Reference - Error 7
Hi all,
I am following the example of 'Dynamically Creating New Files' in the cRIO Developers Guide (P53) but I am getting an error suggesting the path I create is not correct;
The strange thing is.. if I create an indicator of the File Path (19), change to constant and rewire, the error disappears;
Any idea what the issue could be?  It has me stumped Smiley Sad
Cheers,
Pete
Peter D
(4,943 Views)
What happens if you only concatenate the filename and build that with the path "c:\"
That is what I always do.  I never put the entire path as a string...
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(4,938 Views)
Hmm... I tried on my end and no error is generated. Have you tried pulling just that code out and putting in a new VI to see if it happens?
(4,936 Views)
Thanks for your replies.  A combination Smiley Wink
This works with no error.
I restarted my application, re-deployed the host and it works!  It would be interesting to know why it didn't before.. I had been playing around with this for a while, so I possibly didn't close an old reference to "tempdata0".. who knows
Peter D
(4,927 Views)
Hi, There is no need for the sequence, is there
Kind regards,
- Bjorn -
(4,924 Views)
Good point Smiley Very Happy
It's included in my application as I'm also starting the FPGA and initialising some controls in the first sequence.
Pete
Peter D
(4,919 Views)
