Create Table in Access with autoincrement field
I like to create a new table in an access database.
The problem is to create an ID field with autoincrement. I can add "not null" and "primary key" to the field but not the "autoincrement" option.
Do you have a solution for that problem?
Thank you
Marcus
Message 1 of 11
(6,855 Views)
Field i.e. new record or new column?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 11
(6,848 Views)
Hi Ranjeet_Singh,
thanks for your replay.
I create a new table with a new column called "ID" which schoud be "autoincrement".
The records will be added later.
Message 3 of 11
(6,844 Views)
Isn't that a question for Microsoft, the Access help, or a simple google search?
Message 4 of 11
(6,833 Views)
Through SQL you can change the column name I think.
Just google the topic
--Ranjeet
Message 5 of 11
(6,823 Views)
I think it is a problem with the Database Connectivity Toolkit (DCT).
I changed from the ADO Toolkit (http://www.ib-berger.com/index.php?action=adotool) to the DCT.
With ADO it worked fine. But I have to change the code to the DCT. Actually most thinks are working but the autoincrement makes the only problem.
The Picture shows the code of creation.
Hope you can help me.
It is no option to create the tables manually.
Thanks for your help.
Message 6 of 11
(6,799 Views)
May be but this is also because all database providers not provide all the functionality.
--Ranjeet
Message 7 of 11
(6,788 Views)
Here must be an option to read the current primary key number. Search
--Ranjeet
Message 8 of 11
(6,785 Views)
Accepted by topic author Marcus_Körner
Access autoincrement
It seems that if the Autoincrement doesn't work you can try Counter as column specification.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 11
(6,782 Views)
Hope this helps him. Good job
--Ranjeet
Message 10 of 11
(6,778 Views)
