Create Unit Test Vectors From The Unit Test Configuration Window
I have recently been using more test vectors in the unit test framework.
The principle works well but if you are in a unit test and decide you need a test vector you must:
  • Close the unit test configuration
  • Create a test vector
  • Set up your vector (entering values and data types, which is much easier if you could see the actual unit test case)
  • Close the vector configuration window
  • Open the unit test configuration
  • Assign the new vector file to the unit test
  • Now you can assign vectors to test inputs
This seems convoluted and forces unnecessary context switchs.
I propose that at a minimum, you should be able to create a new vector file and launch it's configuration without leaving the unit test configuration window. I suspect that the whole process could be streamlined even further though.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(3,432 Views)
Oops supposed to be ideas exchange, sorry!
James Mc
(3,427 Views)
