Create a 1D Boolean array from a 1D Boolean Array reference
HI,
Any suggestions on how to create a 1D boolean array from a 1D boolean array reference?
Thank you for any ideas?
(4,055 Views)
Accepted by topic author 4BoysDad
You can wire the reference to a value property node and get the boolean array.
(4,051 Views)
Now that I have the 1D Boolean array, what might be the most efficient way to monitor this 1D boolean array for changes in any value.
Thank you for any help.
(4,017 Views)
To monitor a change, you need a loop and a way to compare the current value with the value from the previous iteration. This is most easily done using a feedback node and a "not equal (set to compare aggregates). For example as follows:
What causes changes in the array? Is this a repetitive measurement?
(4,009 Views)
