Create a COM/Activex programmatically
Is it possible to create a COM or ActiveX object programmatically without dropping something on a front panel?
Do you still require the AX container?
Can you mangle the 'name' to be the actual CLSID of the object?
(3,084 Views)
You can use the Automation Open function. You need to provide a constant that's the class that you want to create.
(3,061 Views)
