Create a .NET ReadOnlySpan
I tried to call a dummy property of System.Memory (and wire the output to connector pane to be absolutely sure it was not removed by the compilation) at the beginning of the diagram but it fails in the same location after.
Message 21 of 35
(3,023 Views)
I think it's the ReadOnlySpan that is missing.
ReadOnlySpan is a construct that needs System.Runtime.dll.
Message 22 of 35
(3,015 Views)
Does that mean I have to reference System.Runtime.dll in some way ?
I'll try that tomorrow.
What is strange is that it works perfectly fine in source code, I don't get why it fails in PPL.
Message 23 of 35
(2,995 Views)
I'm not sure, but this is what I suspect.
The PPL runs like a dll. A dll has it's own environment (execution context), so it doesn't accidentally mix resources with the run time (the development environment is the run time when developing).
In sourse code, there's no separation, so the PPL source has all resources of the rest of the source. Either the LV runtime loads system.runtime.dll, or some other code (VI) made it load.
Normally (with normal .net nodes) this isn't a problem, because the runtime context loads the assemblies it needs. However, we're trying to access the assembly dynamically, and that fails because it's not in memory.
Can you use the PPL in the source? Or is that what you've been doing? I'd suspect that doesn't work either, because the PPL can't access the system.runtime.dll dynamically.
It's not the creation of the exe, it's the creation of the PPL that causes this.
Message 24 of 35
(2,984 Views)
Thanks for your kind help.
I'm using the PPL in the development environment.
I still don't have used it with the runtime yet.
I tried to force loading of system.runtime by calling a property of one of its class (type to string or something like that), wiring it on the connector pane, and closing the reference after my readonlyspan use : it fails too in PPL.
I guess it's a generic issue, maybe it's possible to mimic it with other "similar" types.
Message 25 of 35
(2,975 Views)
To be sure, you could check if the string is different in the PPL. Not sure how or why, but a One Button Dialog or string output would prove it's the same.
I'll try this myself in a dll (I stay away from PPLs as I only read about the problems the create 😋 and I don't need them atm).
Message 26 of 35
(2,972 Views)
I'll try to get the type string in PPL.
I'm a PPL user for 2 reasons :
-I'm a TestStand user, and PPL solve a lot of issues between TS and LV
-I live LV plugins architecture
Message 27 of 35
(2,965 Views)
I tried the popup in the PPL : the type is build correctly.
If I wire another popup on the outputed ref with a ToString property it's empty.
I'm stucked at this point 😞
Message 28 of 35
(2,949 Views)
Can you post a minimal example demonstrating the problem?
I haven't touched ppls in a while (that's why I'd done it with a dll, not as an alternative).
Message 29 of 35
(2,941 Views)
Hi Wiebe,
The following image comes from the debugging of a PPL :
Message 30 of 35
(2,246 Views)
