09-26-2019 08:22 PM
I'm trying to build a PID system that controls the input voltage to a linear actuator. My goal is to use a simple control system (PID) to keep the linear actuator vibrating at a fixed acceleration even under external interferences.
I am using BNC-2110 input to read acceleration signals. I have connected a piezo-electric accelerometer to the BNC-2110 input that measure voltage generated from the vibrating actuator, which is then converted in to acceleration (ms^-2 or g- not shown in the VI).
I also use the same BNC-2210 to output a sinusoidal signal that drives the actuaor. A 50 Hz, 1V sinusoidal signal is generated by the labview virtual signal generator (see attachment), which drives the actuator at 1g acceleration. The overall goal is to make sure that input frequency(50 Hz) remain constant at all times while varying the input voltage from 0-10V (using PID) to keep the actuator vibrating at a fixed acceleration of (1g/ 9.8 ms^-2) under external disturbances.
I have been trying my very best to come up with a feasible program and have failed for the last 2 months. It would be great if community members would help me out.
Thank you so much
09-26-2019 10:39 PM
Well... there are some problems in your code. Is this your first LabVIEW project?
For example, the problems are...
You can refer following examples.
C:\Program Files (x86)\National Instruments\LabVIEW 201x\examples\control\PID
How to Synchronize Analog and Digital Input or Output Tasks in NI-DAQmx With LabVIEW
09-26-2019 11:26 PM
Hi Emboar,
Thank you for the quick response. Yes, I am new to LabVIEW and this is my first project.
Can I get your opinion on how you differently would have created the program to make it error-free? It would be great if you can share me a screenshot or even the edited vi file so I can get a better understanding.
09-27-2019 12:02 AM
09-27-2019 01:06 AM - edited 09-27-2019 01:06 AM
Hi Batasel,
So after two month you are still not able to avoid problems like
Have you taken any of those "Training resources" offered in the header of the LabVIEW board?
