Create a Table Control With Only Numeric Entries
I'm trying to create a table control where the user can only enter numeric values of the format %0.3f.  The table controls appear to allow all types of strings and I can't figure out how to limit the formating.  Any info is appreciated.
Thanks.
Steven
(5,181 Views)
The options at the top of my head:
1) Use a 2D array of numerics instead.
2) Perform the filter yourself using an Event Structure
(5,169 Views)
Thanks.  I was hoping to use one of the LabVIEW tables where I could have Row and Column Headers as text, but the actual entries as numbers.
(5,161 Views)
Even i got stuck with the same issue.  if you had got answer could you please share it with us
(4,337 Views)
Hi ashwini,
did you read message #2?
(4,330 Views)
