Create a Timer (with memory ) to use for more than one action
Hi
Problem:
I have created a Timer with an ON/OFF button . But the Timer reset to zero after one action.
**The Timer should be reset to zero only when i colse it with the off Button (Or when i change the value to zero )   otherweise  i wante it  to save the initial value and be ready to use for other actions .
Any help is welcome !
Message 1 of 11
(4,739 Views)
Please post your code. Otherwise, we don't understand where your issue might be.
Norbert
Norbert
Expert: Geometry
Message 2 of 11
(4,738 Views)
Hiere is the code
Message 3 of 11
(4,733 Views)
Hi bibo,
there is no code, there are just 3 images!
Please attach real code!
(And before you do this think about cleaning up, replace locals by wires, think about proper program design…)
Why is there a control without a label?
Why do you set the visibility of this labelless control always to TRUE? Why set the visibility at all?
Message 4 of 11
(4,710 Views)
Hi GerdW,
To be honest i am not the one who wrote this code , i just  have to improve the timer function .
The visibility is used so that when the Button ON/OFF is true  the timer will be visible . But i thinik it s not necessary ..
Message 5 of 11
(4,694 Views)
Hi bibo,
when you want us to improve the "timer function" then you should also attach the missing subVIs…
But you are responsible for this code now - and it is awful!
Message 6 of 11
(4,686 Views)
Hi bibo, Now you are responsible so redesign it . here i am pasting a link this snipet will help you http://forums.ni.com/ni/attachments/ni/170/988115/1/Log%20data.png
Venugopal
Message 7 of 11
(4,663 Views)
I'm not sure I would refactor that monster.  There are so many potential race conditions and bad practices that fixing stuff would probably break the heck out of it.  I would begin by trying to organize it by cleaning it up cosmetically.  Then try to understand what each section of code does before even attempting to optimize.
This will be no small task for even an experienced LabVIEW developer, and quite possibly too big a job for someone whose experience level is indicated by the question that is being asked.
I'm in no way knocking the OP; we've all had to start somewhere.  🙂
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(4,637 Views)
Hi bill, I can understand that, In the above post i have attached a snipet link for timer did u checked it out?
Venugopal
Message 9 of 11
(4,612 Views)
Hi GerdW ,
I couldnt attach the missing subVis so i linked them in this Dropbox link .
https://www.dropbox.com/s/b8bgtvstblawk82/ReMa_v2.0.zip?dl=0
Path: ReMa_v2.00\ReMa_v1.3.7_Trial1\quelltext für ReMa 1.3.7 then simplecurvetrace.vi
I hope you guys are gonna help me even if the code is awfull .
Best regards
Message 10 of 11
(4,600 Views)
