Create a VI by Clicking
Hi. I'm quite new with Labview.
Does anybody know how to create/ duplicate a VI by clicking a button in the front panel?
What I mean is: I have created a template, and I want to write a program such that whenever I click a control button in the front panel, a new VI will be created  automatically, exactly like my template. Can anyone tell me how to do this? I know I can programmatically create a new VI by using Labview VI scripting, but it seems very complicated.
Thank you.
Message 1 of 12
(4,149 Views)
You mean that while the code is running or in the edit mode....? Can you tell what exactly you want to achieve by that?....Smiley Wink
Message 2 of 12
(4,142 Views)
Are you familiar with the template browser?
This is the dialog which shows up if you select File>>New. (No key shortcut).
You can include your own templates there.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 3 of 12
(4,141 Views)
What I mean is: At first I create a template VI. Then with my main VI running, by clicking a button in my main VI, a new VI with its front panel will pop up. This new VI is exactly like the template VI. And I can fill in extra information in the VI, for instance the operating condition of a machine.
Can I do it by using the VI server?
Message 4 of 12
(4,129 Views)
Nobert,
I intend to create a new VI while my main VI is running.
Message 5 of 12
(4,127 Views)
It is still not clear if you talk about the development phase of the application or if this should be a feature of the running application.
If you are talking about development, i suggest you to use the template browser as "main VI".
Norbert
Norbert
Expert: Geometry
Message 6 of 12
(4,123 Views)
Nobert,
It is a running feature of an application. I had created a few subVIs, and I want to create a "main VI" such that the "main VI" will create these subVIs.
Can I use the "open VI reference" to open these subVIs, and save these subVIs under another name, and then open these newly saved subVIs and let it run independently? but how exactly to do it?
Thanks for your advice. Smiley Wink
Message 7 of 12
(4,119 Views)
By the method you proposed you will be able to create a new vi but you will not be able to do any coding there you can simply see the front panel and check the values. And Without running the VI you cannot pop up another VI's Front panel.
By using the Open VI Reference you can invoke the VI into the main VI and can do some operation with respect to the VI and it has nothing to do with coding while the Main program is running..
Smiley Wink
Message 8 of 12
(4,111 Views)
Please take a look into this nugget. It should shed some light on the question for you.
Please note that adding functionality to the called VI during runtime is not possible (at least not in a supported, stable way).
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 9 of 12
(4,110 Views)
If you have the path to the VI you want to copy and the path of the new VI, open the original using Open VI Reference, then use the Save Instrument method to save to a new location.  Make sure you set the Save A Copy flag to TRUE.
Message 10 of 12
(4,071 Views)
