Create a VI that continuously generates random numbers between 0 and 1000 until it generates a number that matches a number selected by the user.
Guys I need help from here (im stuck) and also using just this 3 function on the front panel without using any else.
Message 1 of 12
(10,585 Views)
Hi John,
have you done any basic tutorials?
What's the point of that OR function in your VI? Why did you wire a DBL indicator to a boolean OR input?
Why don't you use the +1 function? Why was the #iterations a DBL indicator?
Message 2 of 12
(10,576 Views)
You are dealing with integers. It is extremely dangerous to have a loop stop on a comparison with DBLs. Except for the random number generator, most of the diagram must be blue!
It is also a poor choice to have the "number to match" default to zero, because zero can never happen in your code and the loop will never stop! Make sure to configure the data entry and default value of all controls before saving.
Message 3 of 12
(10,556 Views)
Here's one relatively safe possibility: (Make sure that the number to match is actually possible.)
Message 4 of 12
(10,549 Views)
If you need numbers in the range from 0 to n you have n+1 possible values 😉
From Help:
Produces a double-precision, floating-point number between 0 and 1. The number generated is greater than or equal to 0, but less than 1. The distribution is uniform.
So check how you coerce ...
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 12
(10,507 Views)
There is a Random Number (Range) VI in the numeric palette.  Use that to make your life a little simpler.
Message 6 of 12
(10,499 Views)
Although not mentioned, perhaps you want to pick each number only once?
0 is included (so technically, it's between -1 and 1000), but I hope you get the picture.
Here's a variation:
Message 7 of 12
(10,485 Views)
Here's a variation:
That loop 'only' create numbers from 0 to 999  😄
Henrik
LV since v3.1
Message 8 of 12
(10,472 Views)
Here's a variation:
AFAIC, The 999 is correct, I mentioned the 0.
"Between 0 and 1000" (mentioned in the title) is from 1 to and including 999, not including 1000, right?
Anyway, I'm sure that can be fixed to meet the demands.
Message 9 of 12
(10,462 Views)
So, how often do you have to generate a random number to match your selection?
guess how the histogram looks like...
Spoiler
No spoiler 😄  .... however I didn't expected that result !
Henrik
LV since v3.1
Message 10 of 12
(10,461 Views)
