Create a connection between LabVIEW and SQL Server
Good Day,
Can you please tell me how i can find or activate the "SQL" option (example in the photos below) on Labview 2019 (32bits).
I have been searching for a long time but I have not been able to find this function.
Thank you in advance for your help.
Best Regards
(2,268 Views)
You Should Install toolkit related to SQL Server.
If you have .llb file, place in the User Library after which you should be able to find in your Functional Palette.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,202 Views)
