Create a cursor on MacOS
Do you know how to create a custom cursor under MacOS ? The Help file says "(Mac OS) The file must be a PNG file or a resource file. You also must wire the ID of the cursor you want to use to the cursor resource ID input. If the cursor image is larger than 16 × 16 pixels, the VI crops the image to that size".
The Create Cursor From File does not work as expected (at least as I expect it to work ;)) : When connecting a png file path, I get an error n° 15 : ressource not found.
What am I doing wrong ?
Chilly Charly    (aka CC)
(3,637 Views)
Hello CC.
I adapt your VI on windows and there is no problem.
I am waiting for a feedback about a test on Mac OS after that I will tell you more about your problem.
Best Regards.
Message Edité par R_Duval le 02-07-2008 10:30 AM
Romain D.
National Instruments France
(3,588 Views)
Romain, you seem to have something in your signature which messes up the page whenever you post. I suggest you remove it and create a new one.
___________________
Try to take over the world!
(3,582 Views)
Hello CC.
Your problem is a bug. If it's a big problem for you, tell me, I will do the necessary to find an issue with the R&D.
A CAR is on creation.
Best Regards.
Romain D.
(3,550 Views)
Thanks/merci Romain
This is not a showstoper bug, nothing urgent.
(3,544 Views)
