Create a matrix
How can I create matrix like this:
1       2      3 . . . .n-2      n-1        n
2       1      2  . . ..n-3      n-2        n-1
3       2      1 . . . .n-4      n-3        n-2
n-1   n-2   n-3 .....2          1           2
n      n-1   n-2      3          2           1
Message 1 of 14
(6,661 Views)
I hate to do homework, if that's what this is.  What have you tried?  My solution uses two For Loops inside one For Loop, with one of the inner ones making the countdown from the left and the other making the count-up part.
Jim
Message 2 of 14
(6,613 Views)
I would​ probably first create a V shaped 1D array going [N, N-1, ... 2, 1, 2, ..., N--1, N], then use a single FOR loop to subset into it with an index based on [I] and fixed length, then autoindex at the output tunnel.
Message 3 of 14
(6,609 Views)
Ramp 1..N. Loop and replace index 0 on each iteration, rotate array in feedback, and index output.
Message 4 of 14
(6,595 Views)
Here's probably the most compact solution. 😄
Try to figure out why it works. 😉
Message 5 of 14
(6,581 Views)
@altenbach That's pretty cool. Super fast, too.  I've noticed that rotating arrays is not particularly fast, so this is much better.  I'm not sure there is much time difference between the absolute and increment operations inside vs outside the loop.
Message 6 of 14
(6,574 Views)
I initially had it inside the inner loop, but identical operations on arrays can potentially utilize SSE instructions for an overall gain by at least a factor of 2, but I am not sure if the compiler would utilize it here. In any case these array operations operate in place, so there should be very little difference. It is even possible that the compiler would generate identical code for the two versions (inside vs. outside) once all internal optimizations are applied. 😄
(make sure to disable debugging when benchmarking).
Message 7 of 14
(6,565 Views)
These might scale even better, no inner loop! 😄
Message 8 of 14
(6,559 Views)
Now you're just showing off.Smiley Wink
Message 9 of 14
(6,552 Views)
Thanks/ I did it with formula node.
Message 10 of 14
(6,522 Views)
