Create a new log file every hour
I have a program which receives measurement data and writes this data to TDMS file. However, I want to create a new TDMS file every hour. When I put a while loop in mu sub vi which creates the new file the program doesn't run. I have attached the sub vi. Can anyone help me out here?
Cheers
(4,175 Views)
How are you running this subVI?  Is it part of another VI?
Your subVI runs.  It has a while loop in it that doesn't do much other than create a new file path every 60 seconds.  It stays in the while loop until the user presses the stop button.  And that won't happen if this is a subVI and the front panel isn't shown.
I don't know why you are obtaining a queue outside the loop.
(4,167 Views)
One trick for doing this is to prepend the file name with YYJJJHH See example
Then just check if file exists (if not create and add headder) when you write to file.
This also generates the reports in "alphabetical" order so windows explorer presents them chronologically.Smiley Wink
(4,162 Views)
Yes this is a sub VI inside another VI. And that is exactly my problem, the sub vi keeps running when I hit stop. Although I don't know how to keep creating new files at a time interval without using a loop...
Will it help if I post the main VI?
(4,137 Views)
can't hurt
(4,126 Views)
(4,123 Views)
