Create a stair step function
I need to create a stair step analog function to control a galvonometer.  I am trying to scan a small chip with a laser.  I have one galvo to move side to side and one to move down the chip.  I currently use a triangle wave on a rising slope but this causes the system to zig-zag across the chip.  I would much rather have the side to side galvo scan straight across the chip.
(4,218 Views)
Are you using a DAQ card to generate this 'stair step' analog function??
(4,192 Views)
We use a PCI-6229 with NI-DAQmx 8.3 to control the galvonometers.
(4,177 Views)
Hello Landauer,
Could you please elaborate as to how you are using the PCI-6229 to achieve this and why it is a problem to have the "side to side galvanometer" scan straight across the chip.
Thank you,
Raajit Lall
Raajit L
(4,154 Views)
Also do post the vi that you are using
(4,149 Views)
