Create a table or excel with dates everytime a boolean is true
Hello, i have a question about how to do this.
 The basic idea of the program is that when i get a true boolean, i want to register one date and time and a measurement, but only once, until the boolean goes false again. Any idea or tip on how to do it?
Message 1 of 8
(3,145 Views)
Hi edison,
so you want to store a measurement on each rising edge of your boolean?
Then use PtByPt-BooleanCrossing to detect such edges!
Message 2 of 8
(3,140 Views)
And how do i save my measurement, time and date after this?
Message 3 of 8
(3,135 Views)
Hi edison,
you save your data using any kind of file write function!
Which format do you need?
The simple way is to create a CSV file by using some string formatting function…
What have you tried? Where are you stuck?
Message 4 of 8
(3,130 Views)
I tried to use write to measurement file and selected to write it in excel, all of this inside of a case structure.
When the boolean that activated the case structure was true it took around 25000 samples, but i only wanted the rms value of the data i got
Message 5 of 8
(3,103 Views)
Are you using an express VI to make this configuration ?
Message 6 of 8
(3,085 Views)
just wire the desired data to the 1D data terminal of the Write Delimited Spreadsheet function. need some format the data first though, if it is a timestamp & rms either double or string can be used, depending on your preference; with the latter being friendlier to comprehend
CY (expired CLAD)
Message 7 of 8
(3,079 Views)
Its always better o share piece of code/Snippet you developed, based on which we can suggest/ Recommend you the approach to solve the solution, Else it will lead to different kind of questions and followed with your explanation.
So Share the code which you tried.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 8 of 8
(3,075 Views)
