03-09-2017 03:09 AM
Use two signals coming from the myDAQ (1000 samples, 500 Hz)
Use a multiplication factor (Knob) for each channel, using a ring control: 2, 1, 0.5, 0.1 V/div
Use a variable shift for each channel (Knob)
Use a zero signal with a toggle switch for each channel
Make the scales (X and Y) fixed (-10 to 10)
How to do this?
With kind regards Dirk Floren
03-09-2017 03:27 AM - edited 03-09-2017 03:32 AM
Hi Dirk,
is this some kind of homework? Your "description" sounds like…
How to do this?
Just follow the hints given in the questions!
- Use DAQmx to read samples as requested
- create a ring control, use the result to multiply your data with
- add a "shift" (aka offset) to your data
- build a zeroing part using a toggle switch
- set the properties of your XY graph
Where exactly do you have problems with?
Did you take the free online beginner courses offered by NI?
(Keep in mind: we don't provide homework for free!)
