Create an array from a string
I want to create an array from String... for example: I have "HelloMarcel" and my array have to look like [Hello, Marcel]...  can I do that with Labview?
(2,932 Views)
Hi nichts,
yes, you can: Split the string after the "o" and use BuildArray with both string parts.
It's the same as with your other thread: you provide an example, that doesn't explain what you really want...
(2,929 Views)
Split string and build array.
Spreadsheet string to array
Search string and build array.
3 examples to achieve that.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,911 Views)
