Create an intensity grid from input voltages?
I am trying to create a heatmap grid of my voltage inputs, how do I set a square to change color from say green to red as the voltage increases? I looked at the intensity plot but with 16 channels coming in it wouldn't separate them (some sort of data type mismatch). If I do a split signal though I can get all the values independently I am just having trouble finding what to wire to them to make the heat map. The only other idea I have is to send the value to the RGB to color vi as one of the inputs and find the right combination that looks like a change in intensity. Then copy that 16 times. is that the best way to do this?
(3,080 Views)
Does this make sense to you?:
Snipet
Screenshot
You can use a for loop for the voltage values, or bind them into array and do the same. I am not sure how the channels behave in a for-loop.
(3,062 Views)
