Create array varible in TestStand 4.0
Hi  gurus,
       I have a doubt that how can we create Array of string in TestStand 4.0 using C#.NET environment.
I used following method, but failed to create array:
objPropertyObj.SetValStringByOffset(10,PropertyOptions.PropOption_InsertIfMissing,"SRU"); // exception here....
The other following method creates array with empty size:
objPropertyObj.NewSubProperty(
"SUBSTITUTE.SRU", PropertyValueTypes.PropValType_String, true, "Arrayw",10 );
Please let me know how to set the length of the array at second method.
Thank you,
regards
RKK
(2,869 Views)
You should post to the TS board.
___________________
Try to take over the world!
(2,860 Views)
