Create array with for loop
Is it ok ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 21 of 34
(2,287 Views)
This is not what i need. How can i make array of 7 axis X values?
Message 22 of 34
(2,275 Views)
This takes the 6 string bytes and creates 3 U16 values of X, Y, and Z.  Then it bundles them into a cluster.  Send the cluster to the loop tunnel and set for auto-indexing.  Or if you want a separate X array, Y array, and Z array, send the 3 U16 values to an auto-indexing tunnel without bundling into a cluster.
Message 23 of 34
(2,267 Views)
When i send U16 value to the loop tunnel, it makes me array with all the same elements, like in my VI. What is wrong?
Message 24 of 34
(2,258 Views)
If you need each scalar inside the loop, do what I told you. You can use a lossy queue to fix the array size.
Message 25 of 34
(2,254 Views)
Message 26 of 34
(2,247 Views)
No. That does not even use the shift register and build array that I mentioned. Here is a very much undebugged and basic example
Message 27 of 34
(2,242 Views)
Thank you for help me with so simple things but i have one more question.
What if i want to have 5 values 1D array of axis X, 15 values 1D array Y and 20 values axis Z?
Message 28 of 34
(2,238 Views)
Use a different lossy queue for each.
Message 29 of 34
(2,235 Views)
Since it sounds like you get 1 point for each axis per loop, you will have to loop the 20 times.  Go ahead and autoindex all of the values out.  You can use Array Subset to reduce the number of samples to work with.
Message 30 of 34
(2,230 Views)
