Create color map intensity graph
Hi!
The intesity graphs have standardly colors blue smoothing to white.
I need to create a color array for an intensity graph with the smoothing colors red-->yellow-->green-->yellow-->red.
I've seen the property node for an array containing colors in RGB, but how do I create an array with the colors I told above? (I don't think I need to type 'em in..!)
And how can I set that the colors are interpolated (smoothing)?
I've never worked with colors/intensity graphs, please give me some tipps!
(4,278 Views)
Hi avr,
there's a property "ZScale.MarkerValues" describing an array of clusters containing a z-value and it's corresponding color. Wire your color/value-pairs to this property.
To allow color interpolation you can switch on this property using right-clicking the chart -> z-scale or set it via property node "ZScale.Interpolate Color".
You can also change colors by wiring an array of 256 colors to property node "ColorTable", but once (LV7.1) I had problems when mixing those two options in one diagram Smiley Sad
Message Edited by GerdW on 09-14-2007 09:11 AM
(4,280 Views)
Hi Gerd,
that's it!
Thank you! Smiley Happy
(4,269 Views)
