Create file in Host.vi
I work with sbrio9631. I created a project of two VIs. The first is running very well on the FPGA, the second is Temp (HOST). Vi
with Temp (HOST). vi I have a problem. I am trying to create a file that I did this always in normal VIs and has already funktoniet why that is not in the Temp (HOST) vi, which is in a project? ??
Message 1 of 24
(6,185 Views)
Hi Anglo,
What kind of file do you want to create, is it something like a txt to save measurements from the sbRIO?
Maybe you could be a bit more specific on this.
Christian
Message 2 of 24
(6,179 Views)
I can not create a txt or TDMS file. it is not all about
Message 3 of 24
(6,172 Views)
Maybe it's becauser there is no "H:" on a sbRIO, only a "C:"
Change the file path and it should work.
Christian
Message 4 of 24
(6,161 Views)
I now have C:\gg.txt  use as path. I get an error any more. but the file is not created, so it is under C:\ do not see  gg.txt
Message 5 of 24
(6,156 Views)
why I do not see the file created?? has to do with the report?
Message 6 of 24
(6,133 Views)
How do you check if the file exists?
What report are you talking about?
Message 7 of 24
(6,124 Views)
So it does not funktoniert. it is given, no error message but I do not see a file in c: \
Message 8 of 24
(6,121 Views)
again: How do you check if the file exists?
Message 9 of 24
(6,116 Views)
bei C:\ müssen alle datei gezeigt werden . und ich gucke unter C:\ und es ist nix zu finden
Message 10 of 24
(6,107 Views)
