Create image from data points
Hi All,
I need some help and hopefully you can point me in the right way. How do I create an image from data points? I have this device that can measure differences in height variation on a sample at different points( x,y,z values ) . I'm just not sure how to print this data  out to an image. Basically I just want a topological map image. I tried to Google different things to get a better understanding but couldn't find much. Anything helps!
(1,378 Views)
On the front panel, go to the Graph->3D Graph palette to find your contour graph.  That will allow you to create the visual.  If you want to save that as a png, use the Get Image property and then Write PNG File.vi.
(1,373 Views)
