Create installation using 8.5 Project
I'd like to know if there is a single, comprehensive source for creating installation files (setup.exe) with LV 8.5 project.  I have a standalone executable that uses the vision toolkit so I have to include the vision RTE.  But I'd like to simpify the install process as much as possible for the end user.  Is there a user's manual that I'm missing?  Is there a third-party book I can buy?
This is the first impression that the customer will get of the software and its currently very cumbersome.
(3,108 Views)
Hey,
I think if you build an executable and an Installer which also contains the Vision Runtime engine, this should be the easiest way for you and the most comfortable way for the customer. He just need to run the installer then and activate the Vision Runtime Engine.
Christian
(3,086 Views)
Try this white paper from the NI site.  It covers how to deploy your code and to do what you want via the installer creation portion of App builder.
http://zone.ni.com/devzone/cda/tut/p/id/3303
Jason
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(3,068 Views)
