Create list with undefined size inside SCTL in Labview FPGA
im using a FlexRio card with the NI1483 module. The 1483 module caputeres images from a camera.
With each clock cycle im getting 10Pixels from my camera. A Pixel can have grayvalues from 0-255.
Now im trying to produce a histogramm of my image with a step for each grayvalue.
The Problem is that i have 10 Pixels each clockcycle and i dont know if two or even all ten pixels have the same gray value.
So i cant use memory and simply set the grayvalue as adress in the memory.
A solution i could think of is 10 memorys one for each pixel, which i sum up at the end of a image.
But is there no easier solution in which i can write multiple times to an memory, array or fifo?
westgate
Message 1 of 1
(2,571 Views)
