Create multiple plots in XY-graph in word using report generation toolkit
How to create the XY graph in word using report generation toolkit?
Please find the below snippet and csv files.
Kindly help me to continue the documentation part.
S Nagaraju.
(3,970 Views)
Hi Sonti,
create an image from your graph after plotting the data. Then embed this image in your Word report…
(3,952 Views)
Thanks for replay,
I know using append control image to report VI, But i want to create the graph using "word insert graph.vi" in word.
S Nagaraju
(3,947 Views)
Hi Sonti,
what have you tried with this function?
Where are you stuck?
Do you get any error messages?
Did you examine the example VIs referenced in the detailed help for this function?
(3,940 Views)
Please find the enclosed snippet.
However XY graph is showing two plots in the one graph, same thing should show when i'm writing in to word.
 S Nagaraju.
(3,909 Views)
