07-28-2017 05:02 PM
Empty path constant
07-28-2017 05:07 PM
Thank You! Got it to work now.
Not sure if I should make another post, but how to automatically save the file without the program waiting on you to tell Excel to "save" file? If the file does exist, and I write to it, I have to go and find the opened workbook and select "save" before the program can continue. Can you automatically write, save then close the excel file?
hiNi.
07-28-2017 05:10 PM
Yes, that is exactly what happens in your "Save Data" case.
07-28-2017 05:15 PM
Hello, when you run the program a second time (that is when the file already exists), the program waits until you acknowledge the "replace file" in the opened excel file. Is there an automatic feature that will allow you to just replace the file if it exists and not wait until you hit the replace button in excel?
Thanks!
07-28-2017 05:32 PM - edited 07-28-2017 05:33 PM
Well when you create the report you have the option to show warnings, but you had that unwired so it should not be showing you warnings. If you run this code below do you see the same behavior? Select a file name for the constant on the left, change the new sheet name after each run and run it a couple of times.
07-29-2017 04:12 PM
I confess to being a little confused. I looked (probably too briefly) at this thread, and thought the question was how to start a new Workbook (if one didn't exist) and then repetitively add data on successive calls. I cooked up a little demo similar to gregoryj's, but then I saw the Title, read the first post, and am now not sure I understand the problem.
My routine, which I'll post if the Original Poster thinks it will be helpful, does the following:
This generates an Excel Workbook with 10 columns, labeled Column 1, Column 2, etc, with the numbers 1 to 100 arranged 10 at a time, going down by columns.
Oh, what the heck -- here it is, even if it does not answer the right question (I apologize for that) ... Oops, can't paste the image (most of it doesn't show), so I'll just attach it as a Snippet.
Bob Schor
08-02-2017 04:57 PM
In response to gregoryj's question....
I do see the same behavior if I run the program a second time. On the first run, if the file does not exist, the program runs and then ends. On the second run (after changing the sheet name), the program hangs and waits until I click yes to replace excel file.
hiNi.
08-02-2017 05:02 PM
Interesting, on mine I do not get a prompt, which is what I would expect since the Save VI has prompt to replace set to false.
08-02-2017 05:08 PM
I think I see where the problem is. I had other workbooks open. If excel if fully closed down, I do not have to select "yes" to replace. If excel is open, I have to select "yes".
In summary, even though the actual file is not open, once Excel is open, I have to select "yes" for the program to continue running. Is this the inherent operation of this code?
hiNi
08-03-2017 02:18 PM
hiNI,
I am wondering if you could use the Write To Measurement File express VI. Forgive me if this is less complex than what you need, but when you create it, you are given the option to select what kind of File Format to export to (.xlsx).
You can also set it to "Save to one file" and then set its behavior if the file already exists.
Then, you can set the "If a file already exists" behavior to "Use next available filename". This will, for example, make test1, test2, test3, etc. if your path is "C:\Users\Admin\Desktop\test.xlsx".If you instead want overwrite behavior, you can set that.
Let me know if this is somehow too simplistic for your application. Hopefully this is some help!
