Create popup help/information
maybe this will help:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 11 of 14
(924 Views)
Ravens Fan, xdaf & Harold. Thanks alot for the help. I have some doubts which i hope to clarify. Is the origin terminal in the draw text at point.vi for database data?  can the popup stay till the user moves the mouse away from the button den disapear? The popup in the vi will only disapear when 1000ms have past. My friend have edited some part of the vi. Will it cause the front panel to lag in his gui design? there are alot of things running in my gui design & he is afraid that it will lag the gui. If anyone have any comment, do leave a reply here. Thanks
Message 12 of 14
(911 Views)
there may be a way to do this with the event structure
Message Edited by Harold Timmis on 09-10-2009 05:52 AM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 13 of 14
(907 Views)
The attached VI will show the picture, then remove it when the mouse leaves.
Things to note are I edited the Mouse enter event case to also include the Mouse Leave event case.  Then, the case structure inside the event handles what to do with the picture
Tim Elsey
Certified LabVIEW Architect
Message 14 of 14
(895 Views)
