Create refnum for control programmatically
Is it possible to create a reference to a front panel control programmatically?
Message 1 of 18
(11,863 Views)
You can open a reference to a VI and from that get an array of all the controls on the front panel, is that what you mean?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 18
(11,862 Views)
I will attach a VI that retreived all front panel controls through Open VI reference. Hopefully this is what you were looking for. I will attach it in LabVIEW 6.0 version
Message 3 of 18
(11,862 Views)
What if the control is inside a tab?
I have most of my controls inside a tab and the property node of Controls for pane does not return those controls.
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 4 of 18
(11,603 Views)
You need to take the Tab refnum and connect it to a property node to get the refnums of the controls on the Tab. From memory I do not recall whether that works page by page or gets all the controls on the tab. Similarly, you can get references to the controls in a cluster or the digital display(s) of a knob... Messy, but useful.
Lynn
Message 5 of 18
(11,559 Views)
To calify Lynn's reply
Tab ref >>> Pages >>> controls on page
And to update the original thread...
FP >>> Panes >>> controls
Ben
Message 6 of 18
(11,556 Views)
 What should I do if I want to get programmatically a control reference, and set his increment.
Do I have to iterate all the FP.controls[] ?
Example: When I click one of the buttons labeled "Multiplier x" (x=1,2,3, etc...), I want to change the "increment" property of another control labeled "Value x" (x=1,2,3, etc...).
See figure, confirm if there is better solution (that is *direct* access to a control reference by naming its label)
Message 7 of 18
(11,263 Views)
I think what you are showing will work.  I do not know of any way to get the direct access you asked about.
What is your concern about this approach?  The time it takes should be insignificant compared to the speed of the user, even if you have many controls on the panel.
Lynn
Message 8 of 18
(11,254 Views)
Indeed it's not working as I imagine because I just discovered there is no property access to "limit".
Even if it worked, it is suboptimal! 🙂
Message 9 of 18
(11,246 Views)
Take a look at this Nugget on using Control references. When you cast the reference as the proper type, you can access the properties of the widget. Here is a preview.
Ben
Message 10 of 18
(11,240 Views)
