Create sequences of waveforms (or other) with different duty cycles and delay
Dear all,
I'm trying to:
1- build a user interface where people will be able to create their own sequence of acquisition (shown here as waveforms signals) with different frequencies and delays. I attached some examples.
2- program it via DAQmx to create analog signals to control different laser power and ON/OFF sequences.
Could you tell me if you have a clever idea to create a convenient user interface?
As you can see, I already tried to do something for 2 signals but it is really difficult and not convenient to use and I'm not totally able to do what I expect (delay and start one/some waveforms).
Best regards
(2,362 Views)
Hi Sebastien,
Right now you show a scalar cluster in one of those images: to create a "sequence" you should need an array of clusters…
I prefer to show such items as a table or multicolumn listbox. Next to the listbox you can provide a way to edit the settings for each step of your sequence, the user selects the step to be edited by selecting a row in the listbox. IMHO that makes a nicer UI/UX…
Example:
A listbox showing a list of items. The user can select one item and edit its settings…
(2,337 Views)
Dear GerdW,
thanks for your reply.
I never used Multicoloumn Listbox before but I'm happy to test your suggestion.
Could you send me your example as vi please?
Sébastien
(2,313 Views)
