Create snippet with VIPM
I am creating my own packages of VIs with VIPM builder.
I didn't find the tips to add snippet (ie when I click on the icon, I want to add the code inside the VIs and not the VI itself).
For example, you can add snippet for the VI "Case (Error IO)" in "OpenG Error" package.
I would like to do the same but how to configure my VI to be added as a snippet and not as a VI ?
Thank you.
(1,366 Views)
Accepted by topic author LoisLbsUromems
You do not configure it in the VI but in the palette where you place the VI.
In VI Package Builder, go to Palettes>Functions Palette, right-click the VI and select Place Folder Contents.
(1,354 Views)
Not obvious to find when you don't know, but works well !
Thank you
(1,328 Views)
I wrote one similar at JKI/VIPM/LAVA some years ago when VIPM was first released. I might do that. Thanks for liking. I hope it is useful for other LabVIEW on Linux adopters out there.
(1,302 Views)
