Create time-limited license for my application
I have created an application for my client, but i would like to add in a function below into my software for license renew.
For example, after the application is used in a PC for one year, it will be locked and will ask user to renew the license, to activate the application again.
Is there anyway can create the time-limited license for my application?
My application is developed by LV 8.5.1.
I am appreciated for your feedback.
Thanks.
(3,656 Views)
LabVIEW does not provide such a feature for applications, you are creating with it.
So, it is your task to implement such a feature into you own application.
Licensing is always a tedious thing: It is restrictive and some kind of overhead, but does not securily prevent misuse... so you have to evaluate on your own what kind of licensing/activation you are using.
Some suggestions:
- Registry entry: Can be changed by anyone familiar with the registry, might be some sort of "date to expire".
- INI-File: If encoded, what about deleting this file?
- Activation tools like FlexLM: Worth the effort?
And never remember: What about the user changing the system time???
In short: You can put much effort with less result into this. So make sure that this is really wanted....
Norbert
Norbert
Expert: Geometry
(3,650 Views)
The Third Party Licensing & Activation Toolkit will do what you want, but you need LabVIEW 2010 or later.
There was even a NI-Week presentation: NIWeek Session: Creating a Software Evaluation for your Product in 10 minutes
Still, I agree with Norbert that an expiring licens is a very dumb idea. What if you go out of business? What if you are on vacation while their license expires? What is the system is on a space flight to Mars?
I would never install software that expires, because if it cannot be guaranteed that it will run a year from now I might as well not use it at all.  If NI would do the same, your LabVIEW 8.5 would have stopped working long ago. 😄
If you want to ensure that users upgrade to a new version, make sure to add new and exciting features. Offer service subscriptions, etc.
(3,632 Views)
Hi Norbert,
I agree with your statement. Your advice is is helpful. Thanks.
(3,587 Views)
Hi Altenbach,
This Third Party Licensing & Activation Toolkit is really useful and user friendly. Sad that i do not have the Labview 2010 or later.
May I know can the Labview 2010 trial version support it?
Thanks.
(3,586 Views)
