CreateElement with LabVIEW --> msxml
I have problems to create an element with the MSXML.DLL (version 3.0).
Thanks!
Sasch
(3,173 Views)
The best way to use this is by using it as ocx. (Place a Automation Refnum
on the front panel, and right click on it. Select Microsoft XML v3.0 Version
3.0. Don't forget to open it with Automation Open, and to close it after
use, using automation Close.)
The rest isn't LabVIEW material, but xml material. Getting started is
easiest with the Load method (fastes results, less effort). create Element
works fine too.
XML is really great, especially in combination with LabVIEW. Regards and
good luck.
Wiebe.
"SaschaS" wrote in message
news:ffdf3535.0204230427.22841d7c@posting.google.com...
> Hi,
> Thanks!
> Sasch
(3,173 Views)
works fine too.
good luck.
Wiebe.
> Hi,
> Thanks!
> Sasch
essage
> Hi,
> Thanks!
> Sasch
(3,173 Views)
